Speedling
- Cedar Lake, IN
- SS
Ok, so obviously I love to go fast. I have tried to do a little tweaking to my engines with what's out there, and made a little progress, but nothing huge.
So people said the pump is the point of limiting factor for it all.
I didn't believe it.
We then watch the 1.8's with 180 hp come out, and be more efficient and faster.
And then the 200 hp superchargers come out, and on a single engine boat the efficiency goes DOWN and we see about the same speeds.
And then you have the Rotax options, of twin 200's and twin 250's that don't go much faster.
AND THEN, you have Berkely, Hamilton, and the like.
So what gives?
I'd love to tell you that I have the answer. And I have got some basic equations figured out, but I have a ways to go in making them accurate in real life.
So what do you guys think are things that need to be considered in all these scenarios?
Here's a list of things I have compared and contrasted between boats/pumps/hulls/engines etc.
Pump size
Horsepower
Torque
Pitch of impeller
Impeller diameter
Number of vanes
Efficiency
Overall water volume coming out of pump
Overall water volume inside of the pump
Surface area of the pump
Rpms of engine and pump
Design of pump and it's optimal characteristics
Weight of the boat in regards to pump loading.
Velocity of water coming out of the boat.
OH! and some things I wondered about...
Do the new Yamaha's have an 8 vane pump? If so, they have the new SVHO pumps which will make a good difference!
And what are the new rotax boats using? The older 155mm pumps from sea doo? Or the newer 159 mm pumps?
I was getting into things like stepped hulls and characteristics of the hull, but kinda stepped away from it due to the fact that there is SO much to look at in regards to researching the engine and pump that I could spend a lifetime.
MMMMMMMMMMMMMMMMk hopefully I get some feedback as I have like 10 pages of research that I'm still sorting through, and a bunch of equations running around.
On another note... one more thing. Anyone know how to make a picture file from an excel spreadsheet graph? Some cool stuff in there I'd love to share when I have it more figured out!
So what gives?
Pump size
Horsepower
Torque
Pitch of impeller
Impeller diameter
Number of vanes
Efficiency
