AR250 Preventing fuel blow back while filling?! Anyone have suggestions?
Zuppy51
SF Bay Area
Just frustrated with pumping fuel and trying to not get it to blow back all over. Today was the worst fuel in my face and clothing.
I’ve tried a few things, but thinking there must be a trick?!
Stopping frequently to allow venting.
ugamarkj
252SD
Mine overflows too. I have someone on-board calling out the fuel %. I stop at 99%
LakesideLaw
Lakeside Marblehead, Ohio
Hmm… have not had this issue. Fuel pumps on trailer …. Gas docks and even 5 gallon cans. Filled up 4-5 times now and no issues with blowback… do you have a kink or blockage maybe?
Zuppy51
SF Bay Area
Po
Never thought of that, i will do some investigation. Thanks for the suggestion.
Seadeals
Greenville, South Carolina
I found holding the nozzle “gangsta” style keeps the fuel flowing in without burps. (Rotate 45-90 degrees clockwise). You might give that a try.
Wicked92
255XD
I only have a burp at the end, when it tops off, I now keep a rag around the nozzle so any splash get absorbed and not running down the side of the boat or on me.
mrcleanr6
new jersey
275SD
Yamaha started putting a chk valve/flapper in the fuel fill hose to the tank. That flapper is possibly getting stuck or not working right. Mine was stuck after winter storage and my first fuel up but after a couple min of fueling slowly, the fresh gas freed it and i dont get blowback anymore. It flows as much as i can pump in it with the nozzle now. There was a thread on here somewhere of a member who took his fill hose apart at the tank to fix the valve that wasnt installed right at the factory. now if your just talking about when the tank finally fills to 100% and it comes up the hose well that is different entirely.
Cobra Jet Steering LLC
Vendor
Florida
Zuppy51
SF Bay Area
Thanks for intel. I checked and could not find any kinks or blockage in either feed tube or vent.
Appreciate the help.
ZGhost
Minneapolis, MN
There is a Vent next to the fuel cap, you might want to check that it was properly installed and open from the factory. I know .... you shouldn’t have to do this but it might be one of the covid quality related issues. The problem could be improper vent installed or defective vent. Might be worth checking. I recall there was a recent thread on this topic, do a search.
212s
1000 Islands
212S
No issues with my 2020 model - takes fuel as fast as the pump allows. I have a good idea how much fuel she will take from the last time out and when close to that amount I listen to flow and once I hear it gurgling in the filler tube I shut it off so it won't splash - always shows 100% when done. Never tried going till the handle kicks off...maybe I'll give it a shot when I have soap and water on hand to wash any spillage off the boat and trailer.
