lokart
- SX
So, I've had several stupid little things that I've had to "make right" on my Yamaha that should have been completed during the build. Lose hose clamps, rusty hardware (Yamaha should have used stainless), bolts over torqued (no anti-seize) and tons of bolts (dash board) that were never fully wrenched (washers spinning on the nuts). But this next thing beats all. I was having so much trouble fueling my boat at the pump. You know what I'm talking about... fuel, click, fuel click, fuel click. Can't even pull the pump handle half way without the dang thing clicking off, no matter the angle or depth of the fuel nozzle - took me forever to fill it up. THAT"S IT!!! I've had it. I purchased a cheap flex scope off amazon and stuck it down the fill tube. Unbelievable! I found this stupid flimsy wannabe back-flow/check valve device that supposedly keeps fuel from sloshing back up through the fill tube. Worse than it being so restrictive, I found it in the fill tube sideways. It wasn't seated squarely in the fill tube, blocking the flow. I pull the floor covering the fuel tank, removed the hose from the tank and found this device stuck sideways in the rubber tube. Instead of pulling it out and placing it where it was suppose to be seated, I removed it completely. Unlikely fuel would make it up the tube. The best part is, this little device is not listed in the parts schematic. I found it at the end of the fill tube just a few inches from the fuel tank. It looks like it is suppose to fit inside the aluminum spout that the rubber fill tube slips over.
