More info at https://jetboaters.net/threads/impeller-bearings-trashed-pics.2822/#post-45245Then I applied some Permatex High Temperature Thread Sealant to threads as a substitute for the Loctite® 567 requested in the service manual.
If you disassemble the pump many other parts require thread sealant and Yamalube Molybdenum Disulfide Grease is needed on the shaft. I substituted Honda Moly Grease which I was able to locate.
I also used a light coating of Life Caulk to form a seal between the pump housing parts. RTV or some other sealant had been applied at the factory.
Its a driving range ball....with that red stripe.....right??
Hopefully I can verify that on Thursday, but I believe you are correct. I'm just thankful it doesn't look like one of my golfballs... If my kids tossed a golf ball down the clean out port to be funny...How
I thought this was a cool video from @JetBoatPilot I use this as a depth benchmark vs the Yamaha 14 or 18" statement3" deep channel going no wake speed. Indian lake.
Wow, from the looks of the video, the stars must have allinged just at the right moment on Sunday afternoon.I thought this was a cool video from @JetBoatPilot I use this as a depth benchmark vs the Yamaha 14 or 18" statement
@Bruce is absolutely right, 567 is a sealant, not a thread locker. You don't need thread locker on those bolts, you need sealant. And just a good waterproof teflon sealant will work.Typically I am not this anal about things but this is an important part of my boat and would like to get it right! If I am overthinking this from you all's experience please tell me to relax!
The service manual depicts Locktite 567 for the 4 bolts connecting the pump assembly to the hull. Has anyone else purchased this or should I just grab the red or blue Locktite from the local auto store?
Thanks Mel, I finally signed up for Amazon Prime and had them overnight the Moly, should be here today.@Bruce is absolutely right, 567 is a sealant, not a thread locker. You don't need thread locker on those bolts, you need sealant. And just a good waterproof teflon sealant will work.
On the pump spline, that moly grease may be hard to find by brand, but like Bruce found, you can use other brands, or...go down to the yamaha shop and if they don't have any in a tube they can sell you, get them to fill a cup with some, because they have it in bulk in their shop.
Fairways and Greens my friend...sorry, couldn't resist!
You think? I was going to say a 1 iron, it's not good for anything else anyway....tough lie... I would use a 9 iron.
I don't see the ball in the diagram??? Was it a stock option or a mod??Typically I am not this anal about things but this is an important part of my boat and would like to get it right! If I am overthinking this from you all's experience please tell me to relax!
