How to install a fume detector with blower control
RobbieO
Sacramento River Delta
212SE
Good idea...This is what I did.
Edit: I edited the picture as it was not correct. The 2 bottom red wires must be connected together and then connected to 87. Leave 87a empty.
I have 2 blowers. From what I’ve been told, one sucks, one blows. Not sure if that is correct, but if it is, I guess I could use 87a. I need a wiring diagram for a12” connect. My bilge switch is touch screen, so I need to find the relay for starters.
Dean P
Florida
Chaparral
VRX
Sorry, I do not know how to do it with a touch screen.
zipper
Boston Whaler
They both blow out, at least mine do. If you are trying to tap into the blower circuit, do it at the blowers and not at the screen. That is where the fume detector will be mounted anyway. Wiring the fume detector/activator circuit in parallel to the blower circuit at the blowers should work, Although, I don't know what system you want to install.
RobbieO
212SE
Yeah, not even thinking of connecting at the screen. Those switches only send a signal, no switching. I need a wiring diagram so I can find the relay. I don't want to start pulling relays and setting codes.
zipper
Boston Whaler
You will be tracing a brown wire with a yellow stripe back to the relay per ABYC standards.
RobbieO
212SE
Thank you...
zipper
Boston Whaler
Your welcome.
RobbieO
212SE
Now that my fume detector is installed, I'm going to wire it to the blower circuit. I want to make sure the blowers continue to operate in auto and manual mode in addition to being activated by the fume sensor. Without a wiring diagram available, I'm going to use the color code chart that @zipper was kind enough to share with me. Being that I have the 12" connext screen, I don't want to be probing too much with my multimeter. I will ohm the circuit from the helm to the blowers to confirm the circuit. I want to make sure the blowers don't get activated simultaneously and the controls are independent of each other. Any insight is appreciated in advance. Thank you
zipper
Boston Whaler
Have you tapped into the circuit? How did it go? I would tap into the circuit with the fume detector blower control wires with a parallel circuit to the blowers. Not a series connection.
RobbieO
212SE
Not yet. Definitely agree. Still determining where to connect.
