How to install a fume detector with blower control
Bizywk
Indianapolis, IN
Agreed. Thanks Julian!
I ordered the upgrade version this morning at a bit cheaper rate here: https://www.amazon.com/gp/product/B01N76K48A/ref=ox_sc_act_title_1?smid=AL09J9CKIG9A&psc=1 For a little more, this version from the same manufacturer promises that it will activate a provided 12vdc relay and turn on the blower for you.
These are available at WestMarine as well if you don't like Amazon, but it's way more expensive there. Also check the sensor after installation and periodically thereafter using just the butane gas from an unlit lighter. Reviews say that the sensors are ocassionally DOA and go bad. The manufacturer reportedly confirmed it. Sensors look very easy to replace though due to a quick connector.
Looks well worth it to me to mitigate risk and potentially automate the process.
Dean P
Florida
Chaparral
VRX
I had to get one. Just ordered this one. Feel better already... :happy:
1619034295663.png :happy:
HangOutdoors
Royal Oak, MI
Anyone Else ??? Wonder how many people will hop on the band wagon :)
Bizywk
Indianapolis, IN
At first, I thought the purpose of this forum was to make friends and share solutions, stories, etc ..... Now I see that it's real purpose is to separate you from your hard earned money!
Dean P
Florida
Chaparral
VRX
I posted that same picture a long time ago. But, you're right! There is always something to spend you're your $$ on. But, when it comes to safety, you cannot disagree with this one! :winkingthumbsup" Every Time, and I mean every time, I start the engine, I think about this. There is no value on "piece of mind". I luv it!!!
HangOutdoors
Royal Oak, MI
If I block a few members for a month, will I save money???
Dean P
Florida
Chaparral
VRX
Dean P
Florida
Chaparral
VRX
Got mine!
Dean P
Florida
Chaparral
VRX
With the Jetboaters.Net mug in the background!!!!
I was wondering if anyone was going to pick that up. LOL!!!
Oh, and the checks in the mail. ;)
HangOutdoors
Royal Oak, MI
I am having an issue wiring this up. On the back of my black box, I have connectors 80 85 86 87 and 87a no idea which one that is for. The below diagram I am following.
I have power coming in off the blower switch power into 30 and 85, I have 86 wired to the yellow ground coming from the control.
is 87 just wired to the yellow wires that are marked blower? off the circuit breakers?
Also I have 87a which is not mentioned.
They also mention another ground in the manual.
2nd picture is the back of my relay that was in the kit.
Any help would be much appreciated, don't want to do this wrong.
Here is the manual.
18141-G-1BB-R-G-1CB-R-G-2BB-R-REV-D.pdf (fireboy-xintex.com)
HangOutdoors
Royal Oak, MI
Yeah I am befuddled since nothing I can find on the web or in their documentation talks about an 87a terminal.
Dean P
Florida
Chaparral
VRX
Took me awhile as well but eventually got it. The relay is all about positive wires, nothing to do with negative wire. On the back of your switch you'll see (from top to bottom) Negative, 12v red and then 12v red. The first red is hot. The second (bottom) is not till the switch is activated. With that said, the relay requires 2 hot 12v running to it. That was what got me. Due to twin engines, I have 2 blowers that work off the switch. So, I tapped into each of the hot wires and connected them to 30 and 86. The second wire (that becomes hot when activated) connects to 87. If you have 2 blowers, the other second wire connects to 87a. Yellow wires connects to 85.
Hope this helps. Let me know if you need anything.
HangOutdoors
Royal Oak, MI
I got it this morning. Will do a diagram, was confusing.
Dean P
Florida
Chaparral
VRX
A wiring diagram would be awesome....even if just hand drawn and photographed.
Good idea...This is what I did.
Edit: I edited the picture as it was not correct. The 2 bottom red wires must be connected together and then connected to 87. Leave 87a empty.
RobbieO
Sacramento River Delta
212SE
I'd like to install one, but I don't have a rocker switch. The switch is built into the Connext screen. I'm still waiting for a service manual and hopefully it will have wiring schematics!
HangOutdoors
Royal Oak, MI
That is how did mine and it worked great.
RobbieO
212SE
So I’m wondering if anyone has installed this system on a boat with the 12” connect screen. My switch is touch screen….I don’t want to spend $500 until I know how its wired. I’ll probably have to do without the blower control.
