I think the consensus is to get the manual controller, which I did, which really is kind of a "semi-auto" as it can move both tabs in parallel in opposite directions, super nice. Check out @Mainah writeup on those, he did a lot of testing of the auto.
Yes. Their product and service is second to none.
They have patented conduit equalizing pressure inside the actuator chamber (when the ram is moving), something that prevents water intrusion in electric actuator tabs. @Bruce has paved the path with them and they have helped a lot of members here. Great guys to work with.
The skills required for installation are hand eye coordination and following written instructions.If you have two thumbs and wish to step up to the challenge, you will be able to complete the install.
I had my fiberglass shop help with the drilling and sealing of the tabs so maybe look into that. They did that part for me for dirt cheap and I just ran the wires myself from there. So much easier that way for me. I hate drilling into fiber glass.
My first hole got me bleeding. I was not very confident with my drill-bit and it poked in placed where it should have not. It brake straight through the rubber and to my middle finger.
That is okay though as God gave me 10 fingers, so one of them bleeding, is not a bit deal.
Installation instructions for my Lectrotabs called for the use of #14 x 1 1/4" S.S. Pan head screws and 3M 5200. I used 1 1/2" due to a 1/4" HDPE spacer I used on my 07. Dont forget to countersink each hole slightly, to help prevent spider cracks in the gelcoat around each hole. Drilling holes in gel coat - The Hull Truth - Boating and Fishing Forum or this video.
I have been lurking around the forums since I bought my boat 3 years ago, I haven’t posted much but have absorbed a lot of great info. I have been looking for a way to get a better ride on the big lakes up here and finally pulled the trigger on a set of @swatski trim tabs. Thanks to all the hard work and advice from you guys and Russ at Lectrotab I am expecting a fairly easy install this weekend. I had them powder coat mine black and went with the ALC, I can’t wait to try them out.
