gmtech16450yz
- SF Bay Area
- Limited S
Ok I had 3 days on the water to play around with the new tabs!
I'm happy with them. The auto mode works exactly as you would expect/want. When you start out from a stop, auto mode turns on at around 8 or 10mph. As you start to plow, the tabs will lower automatically and the bow will drop. Instead of not having the ability to go cruise between 10-20 mph, I can now run at any speeds in that area without getting up on or dropping off of plane. My boat would get up on plane at around 12-15 mph before, and once it was on plane the lowest planing speed would be around 18-20 mph.
Once up on plane, the tabs automatically raise back up. They won't lower at higher speeds unless you manually make them lower. You still get the list corrections, but they're very unobtrusive unless you have 6 people on one side of the boat. So basically you can keep it in auto mode and it doesn't do anything "bad".
The size I used are 12"x 12". They are VERY strong. If I'm running at 50mph and fully lower them, the speed will drop to 35mph. Move them back up and it feels like you just hit the nos. lol. Going 50mph and deploying one side up and one down will make the boat turn almost as sharp as the steering wheel itself. You can turn effectively with the tabs and not even touch the steering wheel. Trying to go straight with one tab down is pretty hard and the boat will list to the side heavily.
There is one difference in having the tabs that I don't think has been mentioned or realized. When I was figuring out where to place the tabs and at what angles I wanted them, I realized that even when fully retracted (up), they will have an effect on the boat's attitude. The instructions want you to basically put the tabs flat with the bottom of the hull. That obviously makes sense and would be how you'd most likely want to do it. Actually that's not entirely correct, they say to have the tabs slightly above the bottom, but only like 1/4" or so if I remember right. Anyway, even if the tabs were a full INCH above the bottom of the hull, they'd have an effect on the boat. The hull of the boat isn't perfectly flat in the water ever, there's always an angle between the bottom of the hull and the water. So obviously anything you do to extend the surface of the hull, even if it's at a higher angle upwards, it's going to be in the water and effecting the attitude of the boat. That's the whole point of ride plates of course.
So the point of all that is this... just putting the tabs on will result in some amount of bow lowering, even if they're at or above the bottom of the hull. In MY experience with MY boat, that's a good thing. My wife actually noticed the difference in ride when we were going through some really choppy water. The funny thing was that when she said the ride was smoother, the tabs were UP! She was right, the ride IS smoother even with the tabs fully up.
The downside could be speed though. My particular speed didn't change a bit, but I also did another mod at the same time I did the tabs that raised my WOT rpm's a little over 100 rpm on each engine. (Another thread for that soon. lol.) If there's a speed cost, it's not much and it's WELL worth the increase in ride quality.
So that's my report. haha. I'm VERY happy with the mod. The install is solid, the operation of the auto controller works perfectly and the tabs DO make a big difference. If I had one request for the guys at Lectrotab, it would be to build a kit that combines a steering wheel position sensor so that you can use the tabs for additional steering power. If the tabs moved quickly enough and moved with the movement of the steering, the turning G forces you could get in one of these boats would be insane! It's even possible they could do it with software and use the gyro and gps that's already in the auto controllers. It already knows when you're turning, a few more lines of code and it could be moving the tabs to aid that perceived turn. The actuators would have to be faster though.
Bottom line, as many of you guys have already said... The tabs are a REALLY GOOD MOD and Lectrotab has the kits that work and the customer service that's above and beyond excellent.
