swatski
- North Caldwell, NJ
I finished a major part of the install and (I think) it went well! It was a bit nerve-wracking as this design is pretty much THE EXACT FIT on so many levels...LOL. I still need to run the cables/ install the controller but when run off of a spare battery the whole set-up seems to work as designed!
Now, I'm anxious about water testing, but in reality there is not much that I would be willing to change. Really the space of the transom/swim deck and their contours give very little design freedom, and there is only that much size-wise I would install there (safely).
I''l post all the install details and more pics when done, but I won't be able to work on it this week.
But - there is progress - here is the evidence !
Retracted vs deployed:
EDIT: more details to follow, but note that in fully retracted position the tabs' upper surface touches the rim of the actuator's ram. These are the shortest actuators available - to afford maximum upward angle possible in these boats, and also to not obstruct anything connected to or going through/across transom U-bolts/hookups.
These tabs will be completely out of the water at speed and should help list the boat but not obstruct the wake on the surf side. That is the idea, anyway!
