BigAbe75
- Litchfield, IL
- X
@swatski its 65 degrees and sunny this afternoon... you testing on the water yet?![]()
Darn I so wish... I'm completely swamped with work cases for the next couple of days...@swatski its 65 degrees and sunny this afternoon... you testing on the water yet?![]()
I will post the install details w/pics, but just in short - yes I used screws.@swatski, Did you use screws to attach the actuators to transom - or use a bolt/nut through hull? Reason I ask is I noted Bruce's install he placed his actuators close to the Ubolt where the hull is thicker - but not sure you have yours that close to take advantage of that. I believe the screws in the Lectro installation calls for 1 1/4' screws and the hull around that area (further from the Ubolt) is probably around 1/2" thick I think or less perhaps. Thanks
Oh, that is coming. Keep in mind that without (a lot of) ballast those tabs just lift the stern up.WHERE ARE THE 10 MPH PICTURES?!!!
I want to see if you can enhance the wake.
Take some St Lunatics with and weigh the boat down.
Can't wait for your update.
Don't let being a river fool you, it can get VERY rough.I guess being on a river, you dont get much in the way of rough water. Would love to know how it affects the ride with 2-3 foot swells.
Oh, I'm not even remotely anxious about that after my first water test (I don't mean to sound snide at all). The first test confirmed the range of the boat's attitude adjustments. These custom tabs appear to be robust, meeting and exceeding all expectations beyond my (fairly conservative) calculations/estimates. I also personally regard this design to be about as heavy duty as I would be willing to test in the hull.I guess being on a river, you dont get much in the way of rough water. Would love to know how it affects the ride with 2-3 foot swells.
The only real alternative to the conventional trims tabs that I have seen are the Volvo Penta QL trim tabs. Would be interested to see a side by side test/review!
@captras Be my guest! Those certainly work, @dan144k and I believe other Yammies here run with those. There are several special considerations where the "interceptors", as QL concept is known, absolutely shine.The only real alternative to the conventional trims tabs that I have seen are the Volvo Penta QL trim tabs. Would be interested to see a side by side test/review!
The install looks great... i am happy you can tell the huge different they make. Just wait untill you get very heavy waves , you put them down and you will get a nice ride regarless offSo - we took off for a quick water test today! the weather was just too nice.
WOW. Those tabs are dynamite! I have to say - surpassed my expectations completely. I wasn't trusting my math and worried with those super short actuators, the range may not be adequate and the tabs would under perform. What a nice surprise!
I am just quickly showing a couple of things here, will run more tests next weekend, hopefully, and then will write it up and report with pics.
First of, the controller works very well and is very intuitive. When I hit and deploy both tabs simultaneously (pushing the "bow down" button) the bow gets almost stuffed, when cruising at 25-30 it is a dramatic effect and the speed drops at least 5mph, the stern pops up about a half of a foot. Almost funny. I was very excited to see such a DRAMATIC adjustment in attitude.
Looking strait down from the swim deck:
Tabs up (retracted) - normal 25-30mph cruise
Tabs down (both fully deployed) - the stern lifts up and rides on the tabs
The same as above but going faster cruise, about 35mph:
Again, tabs up (retracted) - normal fast cruise
And here -- tabs deployed down - riding on the tabs -- the boat really bogs down!
And below are some shots of the deflected wake with one tab deployed (the boat is listed on purpose and kept in strait line - with HARD steering):
Port side (only) deployed
View attachment 51135View attachment 51136
Starboard side (only) deployed
View attachment 51137View attachment 51138
The boat can be steered very effectively with tabs only.
Now, when up at speed the tabs are completely out of the water so, not surprisingly, there is no effect on handling or top speed which is still somewhere in 48-50 mph (7,700-7,800 RPM) range most days in my current my set up.
View attachment 51125View attachment 51126
This system should be a plug and play for simple attitude adjustment, but there is A LOT of testing and work to be done to make it work for surfing. I think the one point most can agree on is that when it comes to wake surfing, any hull/boat would probably gain some benefit from an adjustable trim tab. And in this regard, my tabs were designed with Hippocratic oath in mind (first do no harm) - short actuators and maximum retractability, but appear to still work great!
I think this is going to be one great system - I am cautiously optimistic .
@1948Isaac Like it or not, you are the grandfather of trim tabs in 2015+ 240 hulls, LOL.The install looks great... i am happy you can tell the huge different they make. Just wait untill you get very heavy waves , you put them down and you will get a nice ride regarless off
Lol lol...Great job on the wake wedge. Looks great... Have fun with it@1948Isaac Like it or not, you are the grandfather of trim tabs in 2015+ 240 hulls, LOL.
It is a tight fit, and I wanted to be able to still mount the wake wedge, or a flap devise - which turned out good with enough clearance.
