Nikokrzynowek
- Connecticut
First day out yesterday to break in the engines and it was cut short due to a water leak and bilge pump not working. The plastic tube that goes from the floor drain to the scupper valve had some pin holes in it, leaking water into the engine compartment. Small little pin hole but over sometime it was adding up. Unfortunately I ordered the tube but it is on back order. I tried the bilge pump but the light on the switch was not even on. I was wondering if there is a fuse somewhere for it. I pressed the breaker next to the switch and it doesn’t do anything. Not sure if it’s just a dead pump or if there’s a fuse somewhere
