1.8L Engine Spark Plugs *Smoking Deal*
These are back in stock. I have 12 on the way and the price is still the same!
Shoot to slow on the draw. Says in stock till I go to order then out of stock. I'll try again later
Forgive me if it's been posted before but is the Denso 3381 an exact replacement for the LFR6A? Being told it is but the cross reference is saying it's also good for the LFR6A-11.
The plug th reference may cross to both. The difference is the gaps. And from what I have read, gapping the -11 down to what our engine spec is can possibly cause an issue/failure. Other than that I believe the plugs are the same.
Are these the correct spark plugs for the yamaha jetboats ? Have anyone faced issues when using these plugs ?
NGK V-POWER SPARK PLUGS 6668 LFR6A
http://www.sixityauto.com/8-pc-8-x-ngk-6668-v-power-spark-plugs-6668-lfr6a-tune-up-kit-set.html
EDIT : A set of 8 of these V-Power plugs is 40$ whereas the regular spark plugs are close to $7.77 each on Amazon
https://www.amazon.com/NGK-LFR6A-St...qid=1487969763&sr=8-1&keywords=NGK+6668+LFR6A
Yep, NGK LFR6A is the OEM plug for your boat. No issues.
Only 4 remaining err..
Ordered 8x LFR6A 6668 from sixty auto for $35 shipped with the $5 credit.
Good catch on the $5 discount! I ordered some before all the rest you the 1.8L knuckleheads eat up all their stock!
