14-71 Intercooler Water Plumbing
Mirage
108872
I'll be supplying water from a Dominator pump with the relief valve @ 15 psi and a wanted to know if I should run a separate relief valve so the feed to the intercooler can be at 30 psi as recommended.
108873
buckbuck
Texas
Hang on to your head gaskets. This could be a bumpy ride.
Mirage
Yes 140 MPH in 7 seconds would qualify...at least that what the boat did with the last motor that was in it (1800 HP). I think I'll try to keep her under 100...
