Nothing to it, lots of us have posted pics in the SX 192 mods thread started by
@SamCF, please check it out...but here are the basics. This method requires you give up the wet storage locker drain, but it's no big deal, your bilge pump can handle it with no problem. You also give up using the factory flushing of the intercooler. This is also no big deal. I separately backflush my intercooler from the pisser.
Things you need:
1. One modified stock jet pump strainer cover or an aftermarket jet pump strainer cover plate. I strongly recommend aftermarket for reason already mentioned.
2. One 1/2" 90º threaded fitting to barbed (typically 1/4" or 1/8" NPT)
3. One 2 foot section of 1/2" hose rated for 100psi
4. One 1/2" thru-hull fitting
5. One 10 foot 1/"2 hose
6. Five worm gear hose clamps of the correct size, I used .75" to 1.5"
7. One 1/2" barbed block-off
8. A six ounce tube of marine grade sealant.
9. Small roll of PTFE plumber's tape.
10. Sealing hardware, I bought a gasket kit with many types.
Things to do:
1. Remove your stock jet pump strainer cover if you are re-using the stock plate you will need to grind the cover flat, and drill/tap it for the barb. All that work alone makes it worth the aftermarket cover in my opinion.
2. Install the 90º barb fitting into the chosen jet pump strainer cover. Use plumber's tape on the threads to seal it.
3. Re-install the jet pump strainer cover. Ensure you have oriented the cover so you can properly access the barb fitting when you attach the hose. You can't take it off and re-tape it without removing the cover, there isn't enough clearance.
4. Remove the wet storage locker. This will require you to remove the Phillips screws, most of which will be stripped already. You also need to loosen the coupler clamp on the cleanout port where it ties in to the wet storage locker, and it is also glued to the wet storage locker.
5. Remove the thru-hull wet storage locker drain hose from the thru-hull fitting.
6. Remove the drain thru-hull fitting from the hull.
7. Mount the thru-hull cooling line fitting to the hull. Apply liberal doses of YouTube and marine sealant on both sides of the transom. Seriously, watch a video on Youtube to get some pointers. It may require a trip to the local hardware store to find what you need.
8. Let the silicone set up for at least a couple of hours. Drink a beer or two because the hard work is already done, and its probably hot.
9. Attach the 2 foot hose to the barb fittings on the jet pump strainer and the thru-hull fitting, trim the hose as necessary. Secure with the first two worm gear clamps.
10. Run the 10 foot hose from the intercooler inlet through the starboard midwall penetration, and back to the thru-hull fitting.
11. Attach the thru-hull end of the hose to the thru-hull with the third worm gear clamp.
12. Re-install the wet storage locker floor pan with the screws and re-clamp the silicone coupler with the worm gear clamp.
13. Disconnect the original cooling line from the intercooler inlet.
14. Install the blank barb fitting into the original hose and clamp using the fourth worm gear clamp. Leave it where it is, it's as useful to your boat, as your belly button is to you.
15. Connect your new dedicated line to the intercooler inlet and clamp using the fifth worm gear clamp, trim as necessary.
You are done.
Optional things to do that I highly recommend in no particular order:
1. Install the hi-flow jet pump strainer while the strainer cover is off. It comes with the Riva plate and costs $35 more than just a plate cover with fitting.
2. Intercooler upgrade from the original SHO unit.
3. If you are using an aftermarket intercooler, rig it for 3/4 inch connections and use a 3/4" line instead. This allows you to switch out your intercooler pisser for a 3/4" unit, there are tons of options including your freshly removed wet storage drain. Alternatively, just swap the thru-hulls overboard lines for your bilge (3/4") and intercooler (1/2"). The reason for this is that the water heats up and as it passes through the intercooler it takes a larger volume, even though water mass has not changed. A bigger outlet line will prevent additional flow loss due to water expansion. That's why the SVHO uses two outlets for the one inlet.
