David Martin
- Punta Gorda
- SX
You are correct......and engine builder/create motor is far more likely to have less problem.......The problems in a dealer shop is that most times the guy that has the experience to do it right is not always the guy doing all the work. The main guy gets pulled off to solve other problems in the shop and other hand get involved in reassembly and before you know it some detail get Missed.
Well that's my opinion.
They found the solution it was simple, and you should be good to go out and enjoy........ caulk that one up in the learning collum. Thanks for the post you will help someone in the future.
