Engine Problem on 2024 222S
KoryBehenna
222S
So last September my Port engine started to make a loud pitch noise and the rpm’s ranged about 2,500 rpm’s off from the Starboard engine while at 5,000 rpm’s. Within 5 min the engine cut so we took it in for service. Took 6 months to get parts for the engine from Yamaha for the dealer to fix. This year I went through the break in process again and after only putting 4 more hours on the engine that problem happened again. These engines only have 46 hours on them. These are also the 1.9L engines. Does anyone else’s have engine problems with their Yamahas this often?
There are problems occasionally but it’s rare.
First I’ve heard of an issue with a 1.9 engine. What exactly was the problem?
What was their unsuccessful "fix"?
I’m experiencing a lot of vibration at low rpm on my new 1.9 engines with 10 hrs on them. I was told the engine harmonics may be off, or angle of the engines may be that they are fighting each other. Back at the dealer now. Hope it’s not a long fix like your experience was 🤞🏻
That sounds more like you’ve got something stuck in one or both of the impellers.
