SVTSINR
- White Lake, MI
- Scarab
- Impulse
Has anyone tried the 161 mm impeller and if so how were the results?
TIA
TIA
I ordered the Solas SX-CD-13/18 so it should be here Monday. Hopefully I'll be able to test it by the middle of the week and report back. Everything I read so far says it will work with the 161 mm trim ring and the pump housings are the same. I'm only worried about not having enough horsepower compared to the RXP 300 hp and losing low end / mid range.
Our pumps already have two set screws so you just need to drill two 5/32 hole in the wear ring and screw them in.Remember the set screw. It should be easy to drill and tap the housing to install it.
10-32 X 3/8in
It's always locked at 8000 rpms, I assume that is the factory rev limiter.
Scarab Mike hello I just wanna run this by you! After some research I have found that the scarabs with the 250hp supercharged engine/engines already have a 161mm wear ring and impeller! The 200hp uses a 159mm and the 150hp engines use a 155mm. No wonder it was so tight when I installed my impeller in a 159mm ring. It shaved some off as soon as I started the boat all is well but just wanted to clear this up. This comes straight from scarabs spec sheet on their website!
Ok this was info from the 2016 chart do u know what year they changed from 159mm to 161mm on the 250hp engines? Because I'm 100% the 2016s use a 161mm it's in the chart and I have the pump in front of meI believe I found that chart on the Scarab website when I was doing research. I can confirm that my 2014 is a 159 mm.
There's a big difference between tight and having 2 mm of interference. There's no way you could put a 159 mm wear ring on a 161 mm prop. You would have a giant pile of shavings....
This is probably confusing people, what part number did you end up using? 161 mm?I have a 2016 mid year build and I have a 161mm, so my question is did they change the pump to or is it the same pump different wear ring and prop ?
