- Corinth, TX (DFW)
I know, it's what I signed up for,
The truck starts easily every time with the new starter, glow plugs, batteries,
it drives great after the new front suspension and brakes,
I had fixed all the leaks and not a spot underneath until....
I took a 10 mile drive last week and thought I smelt diesel, figured I had another leaking return line on an injector, when I got home I checked, the top side has never been drier, even the valley pan is starting to flake and previous dirt turn to dust,
after further inspection the mechanical fuel pump was soaked, I turned it on and it would spurt 2-3 drops out, on the engine side of the metal circular part of the pump towards the engine every second, I couldn't tell where it was coming from, the drops where flying 2-3 inches upwards and with the engine running wasn't going to look to closely!
It didn't look like any fuel was coming from the hose connections.
I checked the oil and it was still at the low mark with no fuel smell.
So after reading, I'm assuming/hoping the fuel is coming out of the weep hole that I can see indicating the pump is bad.
So my mechanical friends, @zipper @Babin Farms
This pump is probably 7-10 years old with 20k miles on it, I don't know the brand, a friend changed it when I had hot starting issues (turned out to be the solenoid on the IP)
Many have converted to an electrical pump on these. Do you think it's worth it ? I need easy but I want reliability and frankly getting that arm under the cam lobe sounds intimidating to me (but so does wiring the electric pump!)
