Roger Ski Gapinski
- Other
- Other
- PWC
The shift control cable broke on my 1996 Regal Rush xp120 jet boat! Since the MV-2 control is obsolete I had to replace it with a CH2300P control box. I’m wondering if the new cc21310 control cable will work. I have not received the new CH2300P control yet.
Anyone have any experience? The reason I purchased a new control box is the Interlock Insert was missing half the teeth making it very unsafe to drive. Parts are no longer available for the MV-2 according to the manufacturer Morse - Sea Star Solutions.
Any help is greatly appreciated. I can supply photos when I get on my laptop.
Thanks,
Ski
PS this was posted to iBoats around July 28, 2018. I was unaware of jetboaters.net at the time. Since then, I purchased the xtreme 33c 10ft control cable, the CH2300P control box, fished the cable through the hull and noticed the thru hull connector fitting was cracked. I thought everything was going well until I realized the connector has to be replaced otherwise I will have a big leak into the bilge. Does anyone know if the engine has to be pulled, or the impeller intake grate, or the ride plate have to be removed in order to insert a new connector from the inside? Does the Drive Oil have to be drained before attempting to remove the grate or plate?
I sent a note the Regal Boats product VP and he replied that he forwarded my inquiry to customer service since the boat is obsolete. They also recommended that I take the boat to an authorized Regal Rush dealer for service. It may come to that but the jet boat is 22 years old and I think the repair will be more than the boat is worth. It is worth it to me, however, to try everything I can to get this boat back in the water.
Thanks,
Ski
