212s
- 1000 Islands
- 212S
It's all about the physics - loading and friction are the main issues...it takes torque and hp to turn props or impellers in water to create thrust, and to overcome friction. Unfortunately adding a second impeller or prop off the same engine cuts the power of the engine in half, not double it.Why wouldn't companies like Yamaha put a larger, more economical engine to power the jets? Something that is quieter, with possible gearing so they don't have to rev at 8000 rpm's. LIke what they are doing above. If you want twin jets, then 1 shaft coming off of engine to a gearbox that will power two impellers.
If it was as easy as putting a 6-speed tranny in a boat, all boats would do 200mph with a single 50hp motor. But that's not possible with our technology and physics of water. I believe the Indmar engine they use is not geared, it's direct drive into a jetpump housing just like our boats. I know they talk about it being an Ecoboost engine, but it's nothing like the motor in a Ford car.
In very high hp scenarios it is possible to use high torque to overcome the friction once on plane - such as the massive 600hp V12 Mercury. But even that monster only has a slight bump in gear ratio, not a 6-speed tranny.
