SOLD 2 Wet sounds HTX6 oem amps $225ea
jacoviii
Independence Mo
255XD
I have 2 amps for sale they are oem HTX6 one out of my '18 242x and one new out of a 2020 212x.
I can add RCAs to the oem style plug in male or female it needs only 1 set of L&R RCAs to run the 4 high channels and the 2ch or bridged to 1ch sub channel. I can also add to the oem outputs if needed. at cost of parts (cheap)
Or I can send the clips you crimp on and you could do it yourself.
I wanted to run 2 of these in my 242x but I'm adding more subs (4) and it will be simpler if I do a dedicated sub amp and a new Highs amp.
I will flash the DSP on the amp to make sure L/R are in order. Yamaha wired some of the boats with the inputs flipped but rather then fix the wiring they just reprogrammed the amp.
These amps are set by WS to run 4-8 mids and 1 sub no user adjustments
MIDs RMS Power @ 4 ohm Stereo100 x 4ch watts RMS 4 speakers
MIDs RMS Power @ 2 ohm Stereo150 x 4ch watts RMS up to 8 speakers, 2 per channel
Subwoofer RMS Power @ 4 ohm Mono300 x 1ch watts RMS
I have the oem harness plugs and can add new wire to for you to connect to or I can send the clips and you run your own wires into the oem pugs.
like this.
Thanks for the 2 amps. The sound system is about to get a whole lot better.....
No problem. Let me know if you need any help. Also how was my packing? I did not want anything to move around.
Packing was "a work of art". Arrived in great shape. Thanks for taking such care in shipping. I'll send you a PM when I need some of your expert recommendations. Thanks again.
