blacksapphirez
- Charleston, SC
- SX195
In preparation for the Bimini 2017 trip, I have decided to get me a higher capacity bilge pump. I originally intended to put this as an additional pump but could not find suitable location in the engine bay or the bilge...and running the hoses/wires would have been a huge hassle. So I simply replaced the original 500gph pump and followed the same hose routing. I even used the metal screen that was in the original pump. I (will) enlarged the holes size on the hull for the bigger hose fitting and cut the wire to the existing harness so it can be run with factory switch. Since it is a bigger capacity pump, I imagine bigger fuse may be needed but we shall see.
Bilge 2000gph
https://www.amazon.com/gp/product/B00N6I1DCM/ref=oh_aui_detailpage_o05_s01?ie=UTF8&psc=1
*this bilge has a automatic float switch built in...
https://www.amazon.com/Amarine-made...&qid=1485735683&sr=8-4&keywords=2000gph+bilge
Bilge hose kit
https://www.amazon.com/gp/product/B004XACR90/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Thru-Hull Bilge Outlet (to match the factory look)
https://www.amazon.com/gp/product/B000N9NWZ8/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Bilge 2000gph
Bilge hose kit
