Blkrvrbart
- Sugar Sand
- Tango
So the previous owner sucked a rock through the jet. While the boat is in the shed and it’s still crappy weather, I decided to pull the wear ring and stator. The impeller looks almost perfect, but one of the fins of the stator was dinged and there was a gouge in the back side of the wear ring. Upon removal of the wear ring it exposed a lot of corrosion of the aluminum, had some deep pits on the bottom right at about 5 o’clock looking at it from the back. A few people have talked about using JB Weld in the gouges, but I was all out of JB Weld. I had some high grade epoxy I used instead. After thoroughly cleaning the wear ring and stator, I mixed the epoxy, applied it with a tongue depressor, and when it fully cures in 24 hours I’ll sand it down. Then I believe I can reassemble it all and refill the pump.
How do I adjust the ride plate?
