Do the RPM gauges move when you put the dess key on?2002 Seadoo sportster LE currently have no beep with the harness and not starting. Any suggestions?
no nothing. Do you have any suggestions. I replaced the battery and terminals and still nothingDo the RPM gauges move when you put the dess key on?
no never got a second key. How do you reprogram it?If it’s getting power the dess key likely needs to be reprogrammed. Also check the wires behind the post. Do you have a second key to try?
no never got a second key. How do you reprogram it? How would it go bad if I didn't use it all winter
I will try this as well. ThanksThis happened to me once and it was because the metal tab on the inside of the DESS key was bent and slightly corroded, I bent it back and cleaned up the corrosion and it beeped twice and started right away. Ever since I now put the metal tab on the edge of the post and roll the rest of the key on the post. Never had this problem again.
On the key?Try putting dielectric grease on it
Yes on the metal tab in the key just put a squirt in thereOn the key?
ok i will try that as well. Thanks for all the help.Yes on the metal tab in the key just put a squirt in there
