ddmacrae
- FSH Deluxe
First time on the water this season and ran like a top. Powered down the boat once while on the water, and it fired right back up. Trailered it home, sprayed it off, and connected the engine rinse hoses. Attempted to start the engines, and neither start button does anything. Makes no noise or anything. Batteries are reading 12.5 volts each. Attempted the 5 key reset several times after killing the batteries for several minutes each time. I am noticing a beep sequence during the 5 key reset, but it's different almost every time. Sometimes, it's a long beep, short beep, long beep, while other times it's a single long beep or 2 long beeps. Not sure if that means anything since it's not consistent. I ruled out the cleanout hatch kill switch by looping the brown wires on the engine side. I connected it back the way it was after that and confirmed the switch is completing the circuit when pushed in. It has almost a full gas tank, and the oil levels are fine. It has a brand new house battery, but when I turn the key on, the voltage jumps up to 10.2 volts, then drops to 9.4 volts for a second or so, then jumps up to 12.5 volts. The starting battery jumps up to 12.5 volts almost immediately. I'm not sure if that's something new or not. I've checked all the obvious ground and positive connections. The boat only has around 40 hours on it, and everything looks like brand new. I've checked the lanyard kill switch connection. I have jiggled the gear shifters to make sure it's in neutral. I'm going to check the main relay next, but if that's not it, I have no idea what else to try. Any help would be appreciated.
