Yes, there is a rubber coupler and under that is another o-ring type seal and if they have deteriorated water can migrate back into the engine. That is what I found was the problem with our boat getting water in the oil, I would not think that with your very low hours they would be a issue.After looking at picture closet I already checked the bypass valve. It did have some buildup around the black plastic pressure control valve inside. I cleaned it up and put it back together the first time I pulled all the cleaning lines off. I read in a separate thread about the inner gasket and rubber coupling with the 2 hose clamp bands inside exhaust elbow boot and if it is deteriorated or leaking it could allow water to get into head. Is this true? These are pretty old and could be in better shape
@c_johnsonftw Have you been on the water with it yet?
That mayo may be water mixed with oil. The oil cooler was overfilled. Oil on the dipstick should be between F and L on a cold engine. Filling more than that will force oil up the breather tube. You may want to change the oil before water testing it. With only 37 hours it seems unlikely that the head gasket has failed.The white is stuff was in the hose going from valve cover to the oil reservoir ( the breather tube). It was completely full of what looked basically like mayonnaise and was backing up into the reservoir and around the cap. I’m assuming the salt away and vinegar and CLR I’ve run through it while flushing it has gotten in with the water to the oil and thickened it up to what I found.
When I am flushing I’m getting water out of all 3 spots by jet nozzle indicating I’m getting flow through cooling system. As well as some out of jet it’s self combined with water out of rear pisser and steam & air out of front pisser. I ran both engines and videos the water coming out and they appear to be very similar. Now originally when I flushed boat for the very first time when I got it sand started to diagnose I was getting ZERO water out of exhaust port next to jet drive. I took apart entire exhaust system and checked and cleaned everything and then I started getting water through that port
Harbor Freight has infra-red thermometer. Temps below manifolds near block could be telling. Over 200F not good, but system might flush out on water. Just do not want to run while it is overheating, but could run until it overheats.
