iTzTPATT
- Other
- Other
- Other
Hello all - I have the opportunity to purchase what appears to be a lightly used 2004 AR230 for ~$17,000. I will have to have someone come out to confirm the engine hours, but have been told it was rarely used over the years (a few times each season).
Thought I would check in with the forum to get your thoughts regarding this watercraft? Any significant issues I should be looking for with regard to this year/model? Does 17,000 seem like a fair asking price?
This would be my first jet boat. Only concerns when driving the boat thus far are that the tower is loose (tightened all bolts but still extremely wobbly) and the steering is very tight (guessing it may need a steering cable replacement...seems as if it doesn't have power steering at the moment). Both engines seem to be functioning properly; however I did notice one engine seems to be lacking ~500 rpm at full throttle. Listening to the engines independently you can hear a slight difference, almost as if it has a cylinder not firing. Going to change the spark plugs this weekend to see if that fixes things.
