2004 Yamaha AR230 - Fair Asking Price? Recommendations?
iTzTPATT
Hello all - I have the opportunity to purchase what appears to be a lightly used 2004 AR230 for ~$17,000. I will have to have someone come out to confirm the engine hours, but have been told it was rarely used over the years (a few times each season).
Thought I would check in with the forum to get your thoughts regarding this watercraft? Any significant issues I should be looking for with regard to this year/model? Does 17,000 seem like a fair asking price?
This would be my first jet boat. Only concerns when driving the boat thus far are that the tower is loose (tightened all bolts but still extremely wobbly) and the steering is very tight (guessing it may need a steering cable replacement...seems as if it doesn't have power steering at the moment). Both engines seem to be functioning properly; however I did notice one engine seems to be lacking ~500 rpm at full throttle. Listening to the engines independently you can hear a slight difference, almost as if it has a cylinder not firing. Going to change the spark plugs this weekend to see if that fixes things.
Pending the hours I feel that is pretty close to a fair price. Let us know on the hours. ECUs are the major concern for that model, make sure they are sealed up with some caulk and/or put some flashing over them to keep the water away from dripping on them. There isn't power steering, the steering should not be that tough if you're just idling around or if on plane. I assume the steering cables aren't bad but you can check how the buckets react when on the lift and someone is turning the wheel. 500RPMs is not that big of a deal, could be a spark plug or could be the throttle stop isn't maxed out on the one engine. Check the oil before and after water test to make sure it's not milky, whether it be water or gasoline mixing in with oil. If you're really worried about a bad cylinder you could always get a compression test too!
Above are common issues with the 230s, check it out!
All in all, great boat and motor, very reliable and easy to maintain.
Interior looks in great condition. Salt water or fresh water boat?
Thank you very much for the feedback - I will give that thread a review and certainly check on the ECUs. Will follow up once I find out the hours.
Well below NADA book
Values
Suggested
List Price
Low
Retail
Average
Retail
Base Price$31,999$20,070$22,770
Options (Add)
Total Price$31,999$20,070$22,770
Just be conscious that NADA reflect recent Covid prices. My expectations is that as prices for used boats begin to normalize post-Covid, NADA prices will start to reflect this change.
Jim
Wow, I didn’t expect them to adjust the values that quickly.
NADA didn’t seem to be “Covid” bumped in May 2021.
We paid $39,500 in May. I think NADA average was about $37k. I guess I didn’t save the screen
Currently NADA shows this for my boat
Values
Suggested
List Price
Low
Retail
Average
Retail
Base Price$48,999$37,560$42,650
Options (Add)
Total Price$48,999$37,560$42,650
Seems in the ballpark, given the market conditions. If your scoring a boat like ours for <20k, don’t sweat it and start making memories.
Just a quick follow up a few years later on this post - wanted to thank everyone for their comments! I did end up purchasing the boat for $15K and we've had a great time using it! Thank you for the suggestion on the ECU @Hot2Go - ~18 months into owning the boat I did get gasoline through the exhaust and remembered your post on these being an issue! I was then lucky enough to learn how to disassemble everything to get to the ECUS, ship them off for repair, and reassemble everything (fun times!). Boat runs like a champ - after getting the YDS software I learned each engine only had ~140 hours on them!
Thank you for closing the loop on your thread !
