jws123
- NJ
- SX
First off I am new here so HI I bought a 2004 yamaha sr230 with Non ho mr1 engines for $5300 which is a steal in my opinion. Overall for the age is in decent shape seats are stained and and boat is dirty it was sitting un covered on a lift at the shore I am sure it will clean up. The story iI got was his kids where out on it one day and at the end of the day with the port side engine he thinks they ran the hose without stating first and got water in engine and it sat that appears to be true cause it was all fresh water in engine. The starboard engine runs fine I have worked on vx110 skis before similar engines. The engine was not seized tore it down rings where stuck apparently this engine was rebuilt by sbt not long ago so I cleaned it all up new rings/gaskets threw it back together and it just backfires thorough the intake. To me it sounded like timing issue tore valve cover off and confirmed timing was set right cyl1 TDC both marks lined up on cams. Put it back together same thing pops backfires thorough the intake the compression is 150 all cylinders they had no chance to break in yet. The weird thing to me is if I swap spark plug wires 3-4 it will fire up and run crappy ofc wit a little throttle but with the correct fire order it just pops.. So now I am thinking the old owner had it out this motor crapped out and then they flushed it or tried to flush it while trying to start/not running. So my question is what else could be causing this issue? bad sensor? what controls the timing on these?. Also I just got my yds kit from amazon so I can read the computer/codes but having trouble getting that to work so far it wont connect have watched a lot of vids on setting it up I am going to try another laptop.
Any help much appreciated sorry its so long ahaha.
