2005 AR230 dash rebuild instead of new boat
adamncincy
Cincinnati
Holy mother of God ... this is freaking amazing!!
JetBoatPenguin
Lake James, NC
So after living with it for a while....if you did it again today...what if anything would you do differently on that modification? Just curious....
cybuch
Gilbert, az
Hmmm, the only thing I wish I did was to engrave the vinyl to label what each button does. Other than that, I still love it and my wife know to to use it really well.
GermanAR230
Currently, I am a developer/ analyst for Centurylink. I was a customer car audio installer back in the 90s, that’s where I learned all my customer interior work. I built the dash out of steel, fiberglass, plywood, and of course bondo. I even used an old tshirt.
Any status update (pictures) on the dash rebuilt...? Love the initiative by the way...!
David Martin
Punta Gorda
WOW....great job would love to do something like that but time travel not possible...... to go back when my brain actually worked!!!!!!!
emmanuell
Sorry, I had to share with someone, I think it turned out awesome!
I was looking to upgrade to a new boat, until i saw the prices on the new boats! So, I decided to keep my old 2005 and do some electronics upgrades to the dash. I was jealous of you guys with newer boats that have that touch screen in the dash, so that had to go in! I pulled out the old dash on both sides and rebuilt them both. I upgraded the whole boat to NMEA 2000 network and control.
On the drivers side I installed a 12 inch Raymarine Axiom plus chart plotter MFD, this also doubles as my gauges, digital switcher control, and stereo control. I replaced all the rocker switches with backlit momentary stainless push buttons, including the no wake mode buttons. The buttons are connected to a Yacht Devices N2K digital switcher and flash when the check engine light flashed. I installed a JL Audio head unit and 3 N2K remotes to go with it (one on the passenger side, one in the bow, and one on the rear deck). Perfect pass on the right, with dual power flags (port and starboard) buttons and a GPRS radio below the keys.
On the passenger side, I added one of the stereo remotes on the left, with dual power flags (port and starboard) buttons, a (4) cell phone holder/charger, and enlarged the glove boxes.
Here is the hardware:
  • Raymarine Axiom plus 12inch MFD
  • Albatross Alba-Combi analog to N2K dual engine monitor
  • 2 Yacht devices N2K digital switching (controls all the old rocker type switches)
  • MM100sBE, MM40's
  • 2 Navico N2K fuel flow sensors
  • 2 5v oil pressure sending units
  • 2 water temp sensors
Still need to get it out on the water and test it this weekend.
Thanks for looking.
Hi!!!
Nice and fantastic Job .
immaculate!!!!
do you have a video or more picture?
i will love to do that job
in my boat
nice!!!!
cybuch
Gilbert, az
I do have some more pictures:
I started by building a metal frame and then used wood and fiberglass to shape it
emmanuell
Thanks very much!
do you any video how the new instrument works.
I think I'm going to do something similar, because I have to change the instruments in my 2006 AR230 and I can't find them online, and the It cost $ 450 each, and seeing what you did, it's more modern and beautiful.
Thanks
mikeb4130
Can this be done to a 2015 AR240
I want to delete then Connex system
shaung
What inline water temp sensor did you use?
shaung
Cybuch I know you're busy; I've started the conversion, but I went CHEAP ( dont do that guys) and bought a $100 MarineNow converter thats junk. So I'm gonna get one of these Albacombi units, but it'll need a bit of programming yes?
(EDITED for the cost of MarineNow converter)
shaung
Yes and no. I did cut the wires from the old techs and throw them out. I didn’t install an oil pressure sender tee’d in with the original low oil pressure switch. I also installed inline water temp sensors before the thermostat. For the check engine, over temp, and low oil pressure warning lights, I wired those into the converter and mapped them to the appropriate NMEA code.
CYBUCH I've got mine installed but am having trouble mapping these to work in the Albicombi. Can you help with config instructions buddy?
