2005 AR230 depth gauge
dnimmer
Have a 2005 AR230 and depth gauge works intermittently. I recently had to tighten up Starboard aft pop up cleat and pushed some of the wiring around to get into area to tighten up cleat.
Any ideas of what may be causing intermittent readings. There is continues power to the unit.
I have the same issue with mine on the exact same boat. It has never really worked great!
Same here. Our 2006 SX210 depth gauge has always been intermittent. I was thinking the solution might be to mount the transducer inside the hull but never got around to doing that work. I have a complete spare setup with transducer, cable, and gauge. I've temporarily tried to replace each one but there was no positive change. I gave up and just use it as is. Most boats aren't lucky enough to have a depth gauge. Fact is I know our local lakes and rarely ever need to know the depth.
Where can we find a factory replacement
