BrandonC_OK
- Claremore, OK
First post - I picked up a 2005 AR230 a few weeks ago, I've had it out twice and I'm slowly fixing several small issues. It doesn't have an anchor light but the existing socket appears to be good. Can anyone tell me the length of the OEM pole? I can't seem to find it anywhere.
One more thing I haven't been able to resolve here... water in the bilge and ski locker.
I'm well aware of the metal drain plug at the bottom of the stern. Even with that removed and the front of the boat raised somewhat, there is still a few inches of water in the ski locker.
There is a plastic screw in plug between the tow motors in the engine compartment. I've unscrewed this thinking everything would drain to the drain plug but it didn't. Is it supposed to (maybe stopped up)? If not, what is the purpose of this?
I've read a few posts regarding adding a second bilge. I would assume on an AR230 this would be in front of the divider between the rear area where the existing bilge works and the middle area where the plastic drain plug described above is located.
BTW - this forum has been a tremendous resource as I researched the AR230s and made my purchase. So far I've repaired: blowing out the pee holes, replacing the light bulb for the bow nav lights, drilled out and rethreaded the front tower bolt on the starboard side, replaced the trim on the port locker, replaced rubber feet on multiple hatches, replaced missing cupholders and a deep cleaning!
Other issues needing attention: depth gage isn't working, cleanout plugs need to be rebuilt, horn isn't working, anchor is attached with a cheap poly cord, make poles for cockpit cushions, WAX!, fix loose stand on front of trailer and I'm sure there are more that I don't have on my list. I was shocked that the boat had both the filler cushion in the bow and the cockpit.
Thanks,
Brandon
Claremore, OK
Thanks,
Brandon
Claremore, OK
