2005 AR230 Error Code
DarkstarAR230
I’ve got a 2005AR 230 with the port engine light flashing 6 times then 8 times. I think this means Error Code 68 for a malfunctioning No Wake Switch/Sensor. Am I reading this right? Can someone confirm or shed some light on this? Thanks in advance.
zipper
Boston Whaler
DarkstarAR230
Thanks, I searched the forum first and found that. I need to be more specific am I reading the code right? 6 flashes, then 8 Flashes. Is that 68 or two separate error codes?
zipper
Boston Whaler
Yes, I think you are…six flashes, a pause and then eight flashes is 68. There are no 06 or 08 codes.
DarkstarAR230
Thanks. It was just at the dealer again, a new one since I relocated it from NY to FL and repurposed it as a beach buggy runabout. They did a full system check and it didn’t show for them or they didn’t know what it means. The were reluctant to service it all because of the age, until they saw that it really did have less than 100 hrs on it since I purchased it new in 2005. Now the troubleshooting begins.
