Welcome to Jetboaters.net!
Congrats on the sale. I’m in so cal too. I’ve pulled an engine in my boat and replaced it for under $2k with a waverunner engine. At the time there were several used low hour engines out there. Not sure about now though.
Anyway, good luck with your next boat On to bigger and better things. ????Not your problem now. ?
I figured out that my engine was used in several different waverunners of the same vintage. Then I sourced one from eBay. As a matter of fact, I ended up rebuilding my original and have it in a crate right now. However it’s a 110 hp non ho engine. wouldnt work for you.
