Boat Stuff 2007-2009 AR/SX230HO parts for sale
PaulyB
Bumpass, VA
I sold my Yamaha and and selling all the parts I have remaining.
2- ECU's - 6P6 part number. One is all original with about 350 hours on it, the other has been repaired by Carmo. It had an injector issue. All injector circuits were upgraded during the repair. The ECU has not been tested since returned. I am looking to get $1200 for the pair or best offer. Will split up if needed.
I have a complete throttle/cable assembly. I believe it needs one cable end in the throttle assembly itself. The part number for the part needed is 703-48345-01-00.
I have a new Forward/reverse cable, i bought it thinking I had broken a cable, and discovered it was only the cable end that was broke. I used the cable end from the throttle assembly above.
I have two ECU boxes with the engine harnesses still attached. $500 each
I can get pictures if needed. I am in the process of moving, so it will be as I can get access to the parts for pictures.
Thanks,
Paul
84rzv500r
Lower Keys MM29
PM'd you
PaulyB
Bumpass, VA
ECUs are sold!
