Chumash
Hello,
After not using my boat for a couple of years, I am getting it dialed in to get back on the water. I cannot locate the bilge pump. Looking on the schematic, I thought it was in the engine compartment. Didn't see it there, and doesn't make sense to be there. Is it located under the tray for the cleanout plugs? I had it off several years ago to replace the scupper, and cannot remember if it's in there or not. Before I remove the tray again, I wanted to check and find the exact location. I want to make sure it is still good and possibly add an additional pump. Any info or guidance is much appreciated.
Thanks,
Ted
Thanks,
Ted
