2008 sx230HO Cooling
t1bray
OHIO
Limited
New Purchase . Low hours but has sat for a while .
First run noticed not peeing on port side water outlet . Warning light . After a few revs ,warning light went out .
Question ? Can someone point me to a pic of what each of the water outlet holes are on the side of the craft?
i Have searched but could not find 08 sx230ho pic . Thank you in advance !!!
Want to enjoy her but worried colling system may be clogged .
Scottintexas
Corinth, TX (DFW)
from our FAQ tab above, this video is from one of our members,
also, you may want to look at the link in my sig. below for known issues with your boat
Gym
Falmouth, MA (Cape Cod)
Not peeing doesn't necessarily mean not cooling. The pee holes are merely indicators. You might try pushing a foot to 18 inches of string trimmer line into the hole. It may be as simple as a mud dobber nest.
Scottintexas
Corinth, TX (DFW)
and to be sure what hose goes where you should stick your head under the seat and look up and track each line back to the engine, I certainly wouldn't put it past a Yamaha assembly person to hook the hoses up in reverse order,
t1bray
OHIO
Limited
Thank you all for the replies !
Feeling needy .What Hole is what ? I looked at several threads but did not find whitch hole was for what motor .
buckbuck
Texas
Your exhaust cooling will be toward the front and engine cooling toward the rear. This is a 212X. Not sure if yours are identicle. Just open the engine bay and follow the hoses.
t1bray
OHIO
Limited
that's awesome ! Thank you for the pic .
Now if anyone can tell me if 230's are the same as above 212?
This is a great site.
t1bray
OHIO
Limited
Stupid question . should both Port's -Engine and Exhaust and both Star board be peeing at the same time when running ?
Gym
No. they all should pee above 5000 RPM.
Wisefam22
Lake Lanier ga
So, I have always had one pee hole... port motor now that I know not pee water at the far back. I took my air compressor and blew it from side pee hole and it appeared to shoot a load of water out the back.
I've never had over head light come on but weed wacker string wasnt stuff enough to unclog.
Do you think I could have damaged the thermostat at all by forcing air back through the pee hole? I can now blow air from mouth through and feel it at back from exit hole above port motor.
Beachbummer
Houston TX
I don't think so. Thermostat is a big closed valve with a pretty heavy spring that changes shape when it gets really hot. I doubt some compressed air is going to break it.
t1bray
OHIO
Limited
I don’t think you damaged anything .
My understanding is both motors running
You should have both / exhaust and engine cooling peeing for a total of 4 ports when above 4-5 rpm.
Air compressor is my next try .
I’m taking off exhaust and engine cooling lines and blowing them out .
After looking at diagrams it looks like
Water jacked may be clogged if air won’t work
Wisefam22
Lake Lanier ga
I've always gotten water out of 3 of the 4.. never had engine overheat warnings.
I did run 90miles with fishing line wrapped around port shaft. Didnt find out it was there until removing cleanout port for drive home.
Didnt cavitate or effect my max rpm thankfully.
zipper
Boston Whaler
This is from my 07 Service Manual. It may help. I had to use trimmer string to unplug mine after purchase. Mud dobber wasps had plugged it up causing an overheat alarm. I dont have any water exiting at idle. I do check for the streams once underway.
buckbuck
Texas
@t1bray The 230 HO and the 212X have the same engine.
t1bray
OHIO
Limited
I would like to thank all that replied . I had a chance to work on boat this weekend .
As it turns out the exhaust lines were plugged up with dirt and some insect remains . I
Blew out with compressed air . from engine outward . Both engine lines off of stat also plugged .
Hard to get to from engine bay so used compressed air at line output and blew back out towards the input by the jets .
Alot of crud !! I Will take out to water this weekend . and give feedback . Thanks to all....
buckbuck
Texas
Glad you found the potential problem. Please keep us posted.
Gym
You can put golf tees in the pee holes (ouch) to prevent that problem in the future. Glue a little red gimp to them to remind you to remove them before boating.
