How are things going with the boat ? You decide if your going to do anything with the oil coolers ?
Thanks, I agree on the upholstery. I was thinking about doing that once I know it's running right. I'm still nervous about the starboard side motor. Fingers crossed it's just bad gas. I should know more in the next few weeks.Starting to look much better. Once you do the upholstery it will really turn it around.
I used goof off instead of goo gone as well as an eraser wheel to remove hydro turf (oem and aftermarket) and found that it worked great.
If you use goof off don’t forget to go back over the area with soap/water to neutralize the goof off. I didn’t have any problems /gel coat damage when I used and neutralized goof off this way.Ok I’ll try some of that. I noticed I have two types of goo gone one seems to be sort of an oil/gel and the other is more like an alcohol. I was nervous to use the alcohol version because it says painters pal on it and I didn’t want to hurt the gel.
Also when you say eraser wheel did you use the 3M version like this or one that looks like it has teeth?
