2012 spark plugs??
Trm1765
Red Wing MN
Limited
Anyone have any ideas why my 10mm wrenches and sockets do not fit on the bolts to remove the spark plugs? I think my metric tools might be defective?? 10mm is too big, 9 mm too small....Are these bolts some odd size?
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
10mm = .3937
9mm = .3543
try a 3/8" = .375
Other then that I am getting ready to do my plugs so I can report back when I do.
Trm1765
Red Wing MN
Limited
I tried 3/8 also, and a 7/16.. nothing fits. the 10mm is very close but is just big enough that it slips. The bolts are not stripped at all, they have never been out, original plugs yet.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
What brand of tools are they? I am thinking it should be a 10mm
MidnightRider
Zumbro Falls, MN
Malibu
Wake
Defective socket? Pretty sure it is a 10mm bolt.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
An old craftsman set,, maybe 10mm changed since these were made...
Shouldn't.......that's when craftsman made good stuff.......
Cory
Lake Kiowa, TX 76240
My 2011 uses 10mm to remove coil packs.
Beachbummer
Houston TX
maybe the bolts have grown a bit? rust on the socket? a little lube sometimes makes things slide easier...maybe try that?
Gym
Falmouth, MA (Cape Cod)
NO, tell me it ain't so. This is the 1st plug change on a 2012 boat??? Did you get a tool kit with the boat? There is a long deep spark plug socket that came with mine that works fine. Are you using a deep enough socket?
Cory
I don't think he is talking about the plugs themselves, they are clearly not 10mm, I believe they are 5/8. I think he is talking about taking off the coilpacks to get to the plugs.
Trm1765
Red Wing MN
Limited
Yes, to get the coil packs off so I can get to the plugs.. IF it ever quits raining around here and warms up a bit I will go try it again...
Trm1765
Red Wing MN
Limited
Yes, first plug change.. I seen no need for it, it has ran perfect, still get over 50mph out of it.
