2015 AR190 troubles
No, I noticed it in trouble shooting that a wire was broken in the harness. I didn't see a single replacement harness available and heard that might work.
I tested and didn't see spark. Which is a different harness. I will have to use the wire tester to see what the deal is.
I didn't test it right, I do have spark.
I ordered OEM fuel injectors and will try that next. The new harness has power, I have spark. The injector has to be bad
Glad to hear you found the problem. Hopefully you are back on the water soon and back to peak performance.
Yuck. But thanks for the update. Good to know what the issue was. Are you all up and running now?
