Solas Dual Impeller + Tunnel Seal
I'll get some pictures this weekend, but my surf wave is fantastic. No complaints at all, and I can put it out without the motors screaming at high revs. Could be the difference between the OPs single engine 19' boat and my dual engine 21' boat...
I have a 195, so it's single-engine for me. I'm running about 6k RPM at the optimal speed, so it's not redline-screaming, but I get cavitation on launc with heavier riders if I'm not careful.
Now that's strange - I can't get my twins to NOT bite, even towing a big soggy tube around with three riders
Most recently, I had a 650 bag on the transom, a 375 that was filled to probably 300 on the port floor, and a 450 bag filled to 250 above the ski locker/in the bow floor. Plus 180 pound passenger and 180 pound driver for a total of ~1500 lbs in the boat. And we were pulling up a 230-pound surfer on a nearly 6-foot board. The water was not glass, but not super choppy either. Just average, I'd say.
The acceleration bit initially, but started cavitating pretty quickly on the way up to 10.5 mph. If I launched manually, I could get it to work, but I had to feather the throttle on the way there.
Efficiency!
I think the dual engine and size of the boat make the difference in this case for sure.
I had the exact same thing. The cavitation is 100% gone with the dual impeller, that is a huge plus.
Ahhh! I finally found this thread! The single-engine boat with a dual impeller that is having problems surfing!
So, @dailyderbi, is your Solas impeller different than the Leading Edge twin impellers that @anmut is running?
Did you ever get any improvement on that surf wave with the Solas impeller? I'm a bit baffled as to how an impeller change can impact the wave like yours has, but also nervous as I'm considering switching to a Leading Edge impeller.
Thanks!
