gmotley
- SX
I will try to confirm with GPS tomorrow afternoon.Can you confirm with GPS?
I agree. I live in central Tn. and the temp was about 85F. Previous speed checks were at least 93-95F. I will try to duplicate again and confirm with GPS.The temp outside has a lot to do with it, as well
Can you explain what is ribbon delete?My 2012 SX190 after ribbon delete. The boat was doing about 7600RPM and 43-44mph GPS before (maxed out on speedo). With the ribbon deleted (stock filter in) - I'm hitting the rev limiter at 7800-7850RPM and the boat runs 47mph for as long as I want (GPS; boat speedo maxes out).
The ECU seemed to have automatically adjusted for the added air, and the boat feels MUCH happier, it is snappier and sounds better.
Speedo maxed out (47mph on GPS), 7800RPM on digital tach. Please ignore the depth gauge... I did NOT do it in 1.7 ft of water.
Did some research. I now understand the ribbon delete process.Can you explain what is ribbon delete?
That is very good performance. There are a lot of Supercharged 192's that can't do over 45 mph.
View attachment 29200 Well today i tried to duplicate speed with GPS and failed miserably. I was only able to show GPS speed at 41mph with boat speedometer showing 48-50. I assumed speedometer was accurate from this forum and now I go from proud to pissed. High speed to low speed with this boat is disappointing to say the least. Oh well, to0 late to turn back now.
Hello everyone!
Writing into an old conversation here but I am confused. I have a 2017 sx 190 I have taken the boat out like 3 times and I cannot get the boat past 37 MPH GPS. What could be wrong with my boat?
I do plan to remove the ribbon and add the Cobra fins in the very near future.
