2015 SX210 - no double beep and gauge reset in key start position
LoudenSwain
Yamaha 2015 sx210 170Hrs I went to open it up late this season (2 weeks ago). The batteries were both dead which can be expected after 4 years. Replaced them and was sure to clean all contacts and putting back together as it was. All the electrical seems to work fine. Blower, bilge, lights, gps, etc. Then when I turn either key to the start position there is nothing. Normally there are two beeps and the gauges reset. This does not take place on either key. But the engines both turnover and start along with the gauges resetting and everything is then working. Ive gone through all the fuses at the batteries, engine compartment, and behind gauges. I would think this is very specific and hopefully someone has some insight. Thanks
I had a similar situation with mine. I turn the keys on my gauges cycle, long beep comes on but no blower. Blower works fine on the switch but no auto timed mode. Very strange. Don’t know if it’s programming or what.
