2016 212x Ballast System
sg77799
212X
Purchased a 2016 Yamaha 212x recently. All of the functions work as they should besides the ballast system. When I flip the switch to fill or drain it shows no illumination/power. I located 2 accessory fuses underneath the seat located in battery compartment, both were good. Any ideas? Thanks in advance
Those switches do not illuminate, your pump may have failed. Check for voltage at your pump while someone else hits the fill switch.
