2016 Scarab 195 HOI Water in Ski Locker
Josh Budde
HO Impulse
Hi all,
Here in SoCal a few lakes near me have this Quaggi Muscle inspection and the boat must be 100% Dry (Not even 1 drop of water) or I get quarantined from those lakes for 7 days. What I found out is that water is getting trapped between the ski locker and bilge pump area.
How do I get all this water out to make the boat 100% dry?
luanders
Minneapolis mn
HO Impulse
Hi Josh,
I had the same thing happen with my ski-locker and it is due to the way it was designed... I took a sponge and a bucket and got all of the water out that way for winterization - plus I took a towel and wiped it down to make it nice and clean... other than that, I don't think there's much else you can do...
BobJohnson
Highland Park, il
Chaparral
VR
Can you put a low pressure air pump on the drain line or opening? Blow the water out?
Josh Budde
HO Impulse
Maybe. I used my shop vac to get some out, but now matter what I do, it seems like there is just going to be some water in there. I used an old towel and placed it at the bottom of the ski locker to soak up water while driving to get some of it out. I think I need to get the boat at an angle where the water will go into the bilge pump to pump it out.
Josh Budde
HO Impulse
Hi Josh,
I did the same thing while at the lake when we pulled the boat out of the water. That only gets the water out of the ski locker and not the water that is trapped.
Marc Schauben
Coral Springs, FL
Mine is kept in my garage and I like the boat totally dry when it's stored. I fount that the bilge level (where the bilge pump sits) is higher than the lower bilge behind the ski locker. I made the drain hole a bit larger, bought a cheap pump from Harbor Freight Tools and attached a weighted short hose to it. When I'm ready to put the boat away, I drop the weighted hose through the hole at the rear of the ski locker and suck out the extra water. This was bad design...
Josh Budde
HO Impulse
Something like this?
Marc Schauben
Coral Springs, FL
That's the one.
And I used this hose: tank connection hose for toilet (so it has weight)
Josh Budde
HO Impulse
Perfect.. Going to get this today from HF. Thank you!!
702mireles
Las Vegas, Nevada
HO Impulse
So I have this problem...so to be clear you're saying theres water trapped that I don't see? My ski locker does fill with some water (hot water). when i trailer up and pull plugs I'm on a steep hill and it all drains for the most part. I never noticed water at the bilge pump near the ski locker. just in the locker and again its hot for me. so this pump you have is the fix to the water i can't see? what did you use to cut the hole bigger?
Slugger55
Jasper, AL
@702mireles Take your boat to your BRP/SCARAB dealer and check to see if your carbon seal is leaking....
