2017 242 Limited S e-series on Copart
PaulyB
Bumpass, VA
https://www.copart.com/lot/43980928
From the pics the boat looks to be in good shape minus the fact that the engines are in pallets next to the boat. It also looks like someone installed underwater lights and removed them along with some speakers.
Bruce
Royal, AR
The drain plugs and their housings are missing.
I suspect that the boat was flooded.
Would be very interesting to know the whole story.
Markk
Grand Prairie 75054
Speakers are missing and man I hope that is foam(not concrete) blocks it’s sitting on.
2kwik4u
Georgetown, IN
Are you allowed to inspect the lot before purchase if you're local?
if there isn't hull damage I can see that being worth quite a bit in the hands of a capable mechanic.
swatski
Saint Louis, MO
If it ends up being parted out, I'm interested in the tower.
njmr2fan
Augusta GA
Why couldn't someone with an older twin engine transplant their motors into this and piece off their old boat to pay the difference?
Meetball
This exact thought just went through my head.... my low hour mr1 motors should be able to fit in that without much modification
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
I would want to do a twin V8 setup in it!
PaulyB
Bumpass, VA
You are able to inspect it if you are local. If you aren't local they have companies, that charge a fee, that will go do a full inspection of the boat and they can answer any question you have regarding the condition.
2kwik4u
Georgetown, IN
Boy if I was in a position to have a project, this would be high on the list of things to do.
PaulyB
Bumpass, VA
Yeah I see this boat going for 20kish when the auction goes live.
biffdotorg
Dilworth, MN
The unknown factor will kill it for most remote folks. I agree with the potential submersion. If anything the motors submerged. But then, was it fresh or salt, and then what else will fail after the motors. Was the helm submerged would be a good question.
Fun project. This is the one that would be fun to test a pair of 300hp ACE engines. It's only money.
PaulyB
Bumpass, VA
How do you know it submerged?
Neutron
New Bern, NC
It stated damage: water/flood
J-RAD
Orem Utah
#UltimateSubMove
Cambo
Long Island
There are so many electronic items that were probably under water. My guess on what happened the batteries were turned off leaky hull fittings no bilge pump hooked directly to the batteries and the boat sinks . Or the battery left on the cycling bilge pump killed the battery then it filled with water . I’m local and will take a look later today
boudin
Lake Livingston, Texas
Good ol copart. That is where I bought my AR210 last year, but here in Houston. Let's hope they cover up those engine parts so the internals don't get rained on and do further damage.
-Greg
Neutron
New Bern, NC
Those parts are already toast. Cept for intake and exhaust mostly everything else is close to the scrap heap
PaulyB
Bumpass, VA
I bought a boat last year off copart that said flood/water damage as well, but can find no signs that the boat sank. The only thing I found was a hole in one of the engine blocks.
The owner of this boat could have messed up flushing it and hydro locked the motor and files an insurance claim. Looking at the boat it doesn’t look like it was ever submerged by the pics.
