2018 212x audio issue
Rborland85
I’ll start with I’m not an audio guy, but I’d like to learn. I’m currently having an issue with the cabin speakers not playing. Swim deck, tower, and sub are all good. Just not the two front and two cabin. Found a blown fuse on the amp and replaced it. That wasn’t it. Any suggestions would help.
Fuses don't blow for no reason - if you replaced the fuse and still no sound, most likely there is an issue with the amp and it blew the fuse. You'll need to get the amp tested - any decent audio installer should be able to check it.
