MGoMike
- Michigan
- X
We’ve noticed recently on a few outings that the rear port storage compartment is getting soaked. I’m still trying to isolate the issue, but it seems to occur when draining the ballast. It doesn’t seem to happen every time and I haven’t seen any spot leaking as it is back behind the partition Yamaha installed in the compartment.
I haven’t tested things enough to be sure what is happening, but one thought I had is that it seems to occur more consistently if I’m creeping forward at no wake speeds while emptying the ballast. Anybody else run into a similar issue or have an idea what may be causing the carpet in the rear port storage compartment to get soaked?
