2019 242X Fuel Consumption
CDENsomnia
Linwood, KS
When I received my boat I figured out that the battery wiring is a little messed up so my first few tanks of fuel were not actually saved in the trip information on connext. I am now just leaving the battery switches on and turning the key off which allows all my setting and mileage information to be saved. I was at the lake for 2 weeks and we probably went through 500-600 dollars in fuel. One of those tanks I was able to get some raw numbers and just curious what other 242x owners are getting. When comparing my fuel mileage between this boat and my old AR240 this one is just sucking down fuel like crazy. Keep in mind we are doing the same activities for roughly the same amount of time like surfing, cruising or outrunning storms at full throttle. To me its just crazy this thing is using as much fuel as it is. BTW I fill up at one of the most popular marina's on the water so this isn't old fuel or have any ethanol in it either.
I am getting 1.8mpg on average. I would give my total mileage but I don't think I have those numbers yet.
Whats everyone elses experience? If you don't have numbers, whats your gut say? Burning a lot more fuel than you anticipated?
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
LOL, These big things like gas! 1.8 sounds about right for me also.
CDENsomnia
Linwood, KS
Lol. Yeah but what is it? The towers and bimini? The small size difference? The keel? I just dont get why they would be this bad!
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
I really don't know. Maybe a combination of everything? I know these boats weight more also.
Weeb
Denver NC 28037
I’m about 2.5 mpg with normal cruising.
Matt Phillips
Lake Tahoe
In a long weekend of normal cruising at 6200' the trip computer says about 2-2.2mpg. Depending on weight in the boat, it also showed 11-13gph.
rkgdmd
Live in NY, Boat in Florida Keys
I average 1.9 MPG. 2015 242 Limited S. You shouldn't have to keep your battery switches on to maintain Connext memory.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
You are right, shouldn't being the key phrase. I have seen first hand that his boat erases every single bit of saved parameters he has. Defiantly a winter warranty issue item.
CDENsomnia
Linwood, KS
Yep! Connext is just wired incorrectly on my switches. I have been in contact with my dealer who is 4 hours away and don't want to lose time during prime boating season. So I am just doing this as a work-around.
grywlfbg
NE Oklahoma
Reviving this thread. For reference, I've been out for 2 days now and am averaging 1.9mpg. But we've been tubing at 14-22 (kids are small and we're getting used to everything) so a lot of that time was off plane, pushing a fair amount of water.
But back to the Connext thing. Yesterday I set the clock and created a Drive Control profile for the tube. Today when we went out the clock was wrong and the Drive Control profile was messed up. Is there a fix? Do I need to take it to the dealer or can I fix it myself?
CDENsomnia
Linwood, KS
Yep sounds like you have the same issue I have. You can leave the house batteries on all the time and just turn the key off. I did that most of the summer so I didn't lose any valuable boating time. I plan to take the boat to the dealer to rewire as I just didn't feel like I wanted to dive in to all that wiring. Plus over the phone my dealer couldn't exactly describe what wires needed to change places. I have a couple other small things to go over anyways. ;)
Scrodee
Any details on this wiring? Would prefer to fix it myself as the dealer is 100+ miles away...
CDENsomnia
Linwood, KS
I was going to take mine to the dealer but like you my dealer is several hundred miles away plus the boat is stored at the lake awaybfrom me. I am going to see if I can figure it out myself when I change the oil and wax it.
mcbarronj
Seabrook, TX
I have a 2019 242x e-Series. We saved all of our fuel receipts in 2019, I have crunched the numbers, and here are the results:
Boating Season: May - September
Boat Excursions: 25
Fuel Consumed: 594 gallons
Avg per Excursion: 23.8 gallons
Avg. Fuel Cost: $56.65
Avg. Fuel Burn/Engine: 3.2 gph
Season Fuel Cost: $1,416.34
Croker
Australia
AR195
I think it's mainly down to weight distribution and the jet/jets running at a higher rpm than a standard propeller outboard/inboard. Additionally, the design of the jet boats to be full time wake boats doesn't help especially when you are in a 6 knot zone agains a tide doing 4000 rpm.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
I don't know if you read thru the OPs full post or not but he is talking about the different fuel usage between his old AR240 ( with the same motors ) and his new boat. Before he purchased his boat I told him about the different fuel usage. So the factors you are talking about are not there. We are comparing basically the same boats.
anmut
My 212S gets 1.8mpg on average. That's about 50% cruising at 33mph, 40% water sports, 10% no-wake.
Croker
Australia
AR195
Ah I see my bad.
212s
1000 Islands
With boats, average fuel consumption can be all over the map depending on how you use the boat. Vehicles are different because they tend to be used the same way most of the time so it's easy to notice changes - such as towing uses a lot more fuel.
Personally I don't care about averages for my boat...I care about efficiency while cruising, and the rest is fun. I know I can get 3.0mpg cruising at 27mph using 9.0gph. That's my best cruising efficiency. If I'm going out to do water sports, I know it's going to use a lot more fuel, and racing across the lake or river WOT is also going to suck a lot of fuel - if I"m having fun doing that, I don't care about the fuel usage. Just saying...
:D
Troch1
Bohemia River, MD
Also concur with your gas mileage. 1.8 is almost exactly what I end up with after no-wake, cruising, tubing. I've averaged exactly 2.2mpg on long cruises, but never any better than that. I think it's the top plus the overall weight in combo. Of note, I have straightened my Surf Pointe nozzle setup.
