S1LV3R4D0
- Knoxville, TN
- AR195
Okie doke gang. After a year of dinkin around with the stock setup, ive decided to junk the "obsolete before i bought the boat" Clarion gr10bt head unit. A little backstory for ya. When i bought the boat i immediately went to hitting the source button and low and behold no siriusxm(my fault for not asking ahead of time. I assumed in 2019 it would be state of the art ffs). Theres not alotta cell coverage on Norris so streaming was out. After googling that maybe i could add the sirius SXV300 setup to it...no deal. The unit itself was discontinued before my boat was built so WTF Yamaha. Luckily i had an old car unit in the garage from years ago(i packrat everything cuz you just never know). Bought a power adapter to wire in behind the fuse and a rca to 3.5mm cable to connect it via aux input from radio. Stashed under the dash in the r/s compartment out of the way and whalla, Satellite Radio. My insulated cup covers the stock head unit so its kind of a pain on where they put it anyways.
Anywho, tired of that setup and wanted to replace it and also add a remote on the transom so i bought these with the premise i might add a 3rd set of speakers in the rear also some day down the road.
Fusion MS-RA670 Radio
Fusion MS-NRX300 Remote
SiriusXM SXV300V1 Satellite Adapter
I figured ill leave the stock head unit in the dash, or find something to put over/fill in the hole and put in on the other side of the connext screen. Im gonna remove the phone holder which has never been used at all and cut a hole for the new unit. Good placing for it too.
My question to the electrical/fusion gurus is, is there anything else i will need for the 3 above items to connect to existing wiring other than the cable i have to run to the new remote in the rear?
Also if anyone has any ideas about this setup or the addition of another set of speakers on the rear, please feel free to chime in. Ive learned so much from the small amount of time ive been here with yall. Im always open to new ideas and learnin.
Thanks in advance. Appreciate yall
